Hello everyone, I’ve been diving into the world of KNX integration with Home Assistant and wanted to share my experience, both the hurdles and the triumphs. I recently set up my KNX system using the MDT SCN IP100.01 KNX IP Router, and while the initial setup was a breeze, connecting everything proved to be an adventure.
Initially, I faced challenges with the router not responding under the tunneling option. After some research, I realized the importance of proper configuration in ETS. However, without an ETS license, things got tricky. I discovered that using the KNX IP Router’s web interface was a viable workaround for basic configurations, bypassing the need for ETS temporarily.
Here’s a tip I picked up: always ensure your KNX devices are correctly assigned and their addresses are accurately noted. This step saved me hours of troubleshooting. Additionally, verifying the router’s firmware and ensuring it’s up-to-date was crucial for stable communication.
I also found that integrating KNX with Home Assistant’s scene automation has been a game-changer. For instance, setting up a scene where lights dim and the heating adjusts based on my evening routine has made life so much more convenient.
If anyone else is venturing into KNX integration, I’d love to hear about your experiences or tips! It’s a learning curve, but the payoff in terms of smart home functionality is well worth it. Happy integrating! ![]()
