I’ve recently installed the Kwikset SmartCode 914 Z-Wave lock in my home and wanted to share my experience and some tips for anyone looking to set theirs up. While the installation process was straightforward, I did encounter a few quirks that might be helpful to address early on.
One thing I noticed is that during the initial setup with SmartThings, the lock appeared as a Kwikset SmartCode 910 instead of the 914 model. I’m curious if this discrepancy affects any specific features or if it’s just a naming issue. If anyone has insights on this, I’d love to hear more!
I’ve been experimenting with creating rules to automate my home security. For instance, I wanted to set up an alert that notifies me only when the door has been locked after being unlocked for more than five minutes. While I managed to get notifications for unlock events using the Samsung Safety & Security app, figuring out how to trigger an alert specifically after the lock is engaged proved a bit tricky. After some research, I discovered that using a combination of smartapps and custom rules can help achieve this without constant alerts for every lock or unlock action.
Another tip I’d like to share is about integrating multiple smart devices. If you’re using different brands or ecosystems, ensuring compatibility and seamless communication between devices is key. I’ve found that sticking to Z-Wave for my primary devices has made integration much smoother, especially with the help of a reliable Z-Wave hub.
If anyone has additional questions or experiences with the Kwikset SmartCode 914, or tips for optimizing smart home automation, I’d love to hear from you! Let’s keep the conversation going and help each other make the most of our smart home setups.
