Laundry automation - need help
Hi, i need help to create an automation.
I have a laundry room with:
Smart wall swith h1 eu no neutral one button - for a light and a fan. The wiring of the laundry room is like that.
Smart plug for a dryer
Door sensor
I set the automation when the power consumption of smart plug is above 100w to turn on the smart wall switch and when it is below 90 to turn off the smart wall Switch. So when the dryer is working the fan also works.
Another automation i have is when i open the door smart wall Switch is turned on and when is closed to turn off wall Switch.
But i want when i am in the laundry room and if the dryer switched off, the light (wall switch) to remain on (if the door sensor is opened).
Can you help me how to create the automation?
Hello, welcome to the forum.
I am currently writing a new lesson 7 on the bathroom, I use a humidity sensor to control the fan. Maybe you will use something for yourself.
If possible, follow my lessons. Automation 2.0. Lesson 1. Introduction
