LED on the wireless button in H2 switches
Setup:
I have two Aqara Smart H2 US light switches (4-buttons). In these switches (as everyone knows). 3 buttons are with relay and the fourth is pure wireless. Button #2 on Switch-1 is wired to turn on the lights of a hallway and the 4th button (Wireless) on the Switch-2 is used to trigger the button #2 on Switch-1.
Situation:
Hallway is long and Switch-2 is in a place where one cannot see if the hallway lights are ON or OFF until you walk to the hallway after pressing the 4th button on Switch-2. If the lights were on, and someone presses the 4th button to turn the lights on, they inadvertently turn the lights off since there no led feedback on the 4th button.
Need help:
Is there a way to turn the 4th button LED ON/OFF using Automation?
If this feature is not available then can this please be put on the list of improvements?
Hello @apnahouse
This isn’t currently possible because it’s a wireless button, and the indicator displays the relay status based on the app settings. Good idea, thanks.
Thanks for a quick response. I understand it is not possible at this moment. However, it should be put on an improvement list since there is an LED on the fourth button and during “Find your Device” using APP, it blinks. So technically feasible to have it turned on through automation if the option is made available.
Any updates on this? It really seems like it would be an easy automation to control the individual switch indicator lights on both the WiFi switch and any of the other decoupled switches.
