Hi.
I have many smart lights at home, they all work with adaptive lighting. T1 strip also says it supports adaptive lighting, in Home app it is set to adaptive lighting, but it doesen’t work. Always same temperature of white color. Am I only the one with such bug?
Hi @m_tretiakov
Thank you for reporting these issues. I hope they will be fixed soon.
@AqaraOfficial
I’m not aware of this as an issue. Not sure if it’s a bug or issue with your unit? Does tunable white work if you change tones manually?
I’d separate manual tunable-white control from the Adaptive Lighting schedule first: set two fixed white temperatures in both Apple Home and Aqara Home, then reselect Adaptive Lighting and observe it for a while. I’d also note whether Apple Home sees the strip through native HomeKit or an Aqara Matter bridge. If manual temperature changes work but Adaptive Lighting remains fixed, that narrows the problem to the Apple Home capability/update path rather than the LEDs themselves.
