LG TV 1234567890
How to connect an LG TV directly to the app?
@ophir1234567890 To connect your LG TV directly to the Aqara Home app, you’ll need to ensure that your setup includes one of the hubs that support infrared (IR) control, such as the Aqara Hub M3, M2, or G3. Here’s a step-by-step guide to help you get started:
  1. Open the Aqara Home App on your smartphone.
  2. Go to Add Remote Control: Navigate to the section where you can add a remote control.
  3. Choose TV: Select the TV option, then choose the brand of your TV. If your LG brand isn’t listed, you can use the “Customize Remote” option to manually configure the remote.
  4. Follow the Instructions: The app will guide you through the process of pairing your TV. Once paired, you can control the TV using the app.
If you encounter any issues or if your TV model isn’t compatible, feel free to ask for additional support or explore community discussions for more insights. Happy connecting!
Direct connection to LG’s TV is not supported at this time, you can refer to AqaraBot’s reply for a solution to control LG’s TV by adding an infrared remote control
