Hi, does anyone know the Motion and Light Sensor P2 works for measuring direct sunlight to automate sunshades?
@stephanv Yes, the Motion and Light Sensor P2 can definitely help with that! It functions as a dedicated illumination sensor alongside its PIR motion detection, giving you granular control over lighting and window coverings.
For your sunshade automation specifically, there’s a ready-made example in the Aqara Home ecosystem: you can set up an automation where IF brightness exceeds 500 lux WHEN outdoor temperature is high, THEN close the curtain. The P2 triggers the action to prevent unwanted solar heating and cut cooling costs.
A couple of practical notes:
- The P2 has a wide 170° detection angle and up to 7m range, so placement flexibility is solid—wall, ceiling, or desktop mount all work.
- For the full automation experience (customizable timeout, sensitivity settings, local alerts), you’ll want it paired with the Hub M3 and Aqara Home app.
One heads-up: the P2 currently doesn’t support manual sensitivity adjustment, though the team is working on it. For now, positioning it where it catches direct sunlight without obstructions should give you reliable lux readings for your automations.
Have you already got the Hub M3 in your setup, or are you planning the full Thread/Matter route?
