I’m in the UK and want to change my light switches to smart switches. There doesn’t seem to be many options so what are the Aqara ones like?
I am using the H1 EU switches in gray, throughout my house and they work great the only downside is they are deep fit (30mm if i remember right) so if you have half depth switch boxes in your wall like most do in the uk you will need to either have them changed for full depth or use an extender and have the switches sticking out from the wall.
First picture: Aqara H1 (double rocker, there is also a single rocker variant), second picture: Aqara H2
The H1 is an older model, Zigbee only (Aqara hub required). When buying it you need to check if you’re buying a “with neutral” or “no neutral version” (neutral version is better, but depending on your current switches wiring, you may need the “no neutral” version). The H1 is so big that unfortunately it cannot be installed in all multi-gang setups.
The H2 is a newer model, which also supports Thread. It doesn’t require an Aqara hub (it can connect to third party Thread hub like a HomePod). There is no distinction between “no neutral” and “neutral” versions, because all H2s support both modes. And (as you can see in the picture), the H2 can be installed next to each other and support multi-gang frames.
When buying the H2, check other sellers apart from Amazon. There is an Amazon-exclusive version (white color only) and the WS-K07D/WS-K08D model with white and grey button option (not sold on Amazon).
I have the H1 switches and they work flawlessly. No complaints, I have repurposed two of them as smart switches (the power always stays on because I have installed smart light bulbs). Very easy to install and retrofit your current setup.
