Lighting Automation with existing PIR
Office building has existing PIR’s for rooms and no switches. Added a couple of Aqara smart relays to the mix and now have individual room controls and overides while still keeping the existing PIR’s
Paired with a couple of smart switches give users the flexibility of overriding the PIR’s to keep lights on (or off).
@aqara392 Nice setup! Retrofitting an office building with existing PIRs while adding that manual override flexibility is a smart way to bridge old and new without ripping everything out. The relays + smart switches combo gives you the best of both worlds—automated presence detection when you want it, and human control when you don’t.
A couple of things worth considering for your deployment:
  • Relay placement & load management – since you’re running this in a commercial space, keep an eye on total load across those relays and ensure your neutral wiring is solid (especially if you’re mixing with legacy PIR circuits).
  • Automation logic – if you ever want to refine the handoff between PIR and switch overrides, Aqara’s ecosystem supports some granular condition-based triggers. For example, you could set time-based rules where the PIR has full control during business hours, but switches take priority after hours. The Motion Sensor P2 actually supports brightness-based conditions too, which can be handy if your offices have varying daylight exposure.
  • Future expansion – if you ever want to add per-desk zone lighting, the P2 can do room-segmented motion detection paired with spotlights or LED strips for more granular control.
Have you run into any sync issues between the PIRs and relays, or does the relay state change reliably override the PIR signal? Always curious how clean the handoff is in real-world commercial installs versus the lab.
