Link M1S hub in Homekit to other brand sensors in homekit as Alarm
Is it somehow possible to connect other brand their motion sensors to the aqara M1S alarm in homekit?
@djmshane Connecting motion sensors from other brands to the Aqara M1S hub in HomeKit is indeed possible, but there are some considerations to keep in mind. The Aqara M1S hub, when integrated with HomeKit, can interact with other HomeKit-enabled devices, including motion sensors from different brands. This means you can set up automations within the Home app to trigger the M1S alarm based on inputs from these sensors.
To achieve this, ensure that all devices, including the Aqara hub and third-party sensors, are added to the HomeKit environment. Once set up, you can create automations where, for example, the M1S alarm is triggered by motion detected by any compatible sensor.
It’s a fantastic way to enhance your smart home system by utilizing the strengths of different brands seamlessly. If you have further questions or would like to share your setup experience, feel free to dive in and discuss with the community!
@AqaraBot is there any guide on how to set this up in the homekit app? I tried multiple things but no success yet
@djmshane Setting up other brand motion sensors to work with the Aqara M1S hub as an alarm through HomeKit can be a bit tricky, but here’s a general guide to help you get started:
  1. Ensure Compatibility: First, confirm that all your devices, including the Aqara M1S hub and the third-party motion sensors, are HomeKit compatible.
  2. Add Devices to HomeKit: Use the Home app on your iOS device to add each device to your HomeKit environment. This typically involves scanning a HomeKit code on the device or its packaging.
  3. Create Automations: Once all devices are added, open the Home app and navigate to the “Automations” tab. Here, you can create a new automation by selecting the “+” button.
    • Choose a trigger, such as “A Sensor Detects Something,” and select your third-party motion sensor.
    • Set the condition for the automation, like “When the sensor detects motion.”
    • Select the action you want the M1S hub to perform, such as triggering the alarm.
  4. Test Your Setup: After setting up the automation, test it to ensure that the motion sensor properly triggers the M1S alarm as expected.
Unfortunately, there isn’t a specific Aqara guide for integrating third-party sensors in the HomeKit app. However, the steps above should help you set up basic automations. If you encounter any issues, the HomeKit community or the Aqara forums are great places to seek additional advice and share experiences. Feel free to ask more questions or share your setup experience here!
@djmshane Setting up your Aqara M1S hub with third-party motion sensors in the HomeKit app can indeed be a bit tricky, but it’s a rewarding process once you get it all connected. Here’s a general guide to help you get started:
  1. Ensure Compatibility: First, make sure that both your Aqara M1S hub and the third-party motion sensors are compatible with HomeKit. This is crucial as HomeKit compatibility ensures that devices can communicate seamlessly.
  2. Add Devices to HomeKit: Open the HomeKit app and add your Aqara M1S hub and third-party motion sensors. This usually involves scanning a HomeKit code or following the manufacturer’s specific instructions for adding devices to HomeKit.
  3. Create Automations: Once your devices are added, you can create automations. Go to the Home app, tap on the “Automation” tab, and create a new automation. For instance, you can set the automation to trigger the M1S alarm when motion is detected by the third-party sensor.
  4. Test the Setup: After setting up the automation, test it to ensure everything works as expected. You might need to adjust the settings based on how responsive you need the system to be.
Unfortunately, specific guides from Aqara for integrating third-party devices might not be available, as it largely depends on the HomeKit app’s capabilities. If you still encounter issues, I encourage you to reach out to the community for shared experiences or consult additional HomeKit resources for in-depth instructions. Keep experimenting, and don’t hesitate to ask for help. Good luck with your setup!
