Local storage playback issues
Has anyone been having issues with a G3 camera local storage? I can’t seem to get my 24 hour recording to playback properly. Ever since aqara came out with the guardians subscription local storage have been acting funny.
My local storage works properly. You can try formatting the SD card in the camera settings, as sometimes something may change/break between firmware updates, which can cause the local storage to malfunction.
The SD card may also be faulty. Unfortunately SD cards (especially cheaper ones) are known to fail, this is not a good long-term storage. For example many photographers (even with their more expensive cards) use cameras with double memory cards (to have a backup in case one of the card fails).
Personally once a few months I encounter a problem when my G2H stops saving to local storage - I reformat the card to fix this when it happens.
Thanks for the advice! I guess I’ll have to buy a new SD card. I’ve tried formatting it multiple times, but I still haven’t had any luck. I’m using a Kodak card, so I’m not sure if that’s considered a cheap brand.
Unfortunately all SD cards fail sooner or later. But you can setup NAS storage as more reliable local storage. You don’t even have to buy any new hardware - if you have a PC (or an unused laptop/Mac Mini) you can install a file server and it will just work as a NAS. Macs have a file server built in as file sharing option in system settings.
