I have two automations in Aqara Home. They are identical except that one turns on a light, and the other turns off the same light. Each checks security is set to Home.
Am I right to assume that by setting the light brightness and temperature, that is stored in the cloud? If so, can’t that be a local operation?
Try deleting the automation and creating it again. I remember that worked for me once. It’s been a while, though. The app version and Hub firmware might be different now. Anyway, just give it a try.
Deleted and re-entered. Still cloud.
BUT… If I just turn the light on without setting brightness/temperature, then the operation is local. ![]()
You’re right.
With individual actions, it’s local:
But not with the combined action:
Probably a bug.
Could be. Since the end result is the same it should be a matter of needing cloud for extra process time.
I think this is costing Aqara money unnecessarily.
Should we report this to support?
