Lock U600 but both screws are below the handle
Silly question but I bought myself a U600 and was happy with it.
Bought another one as a gift for a friend but before I attempted installation I noticed that strangely both the existing screws for the handle are below the handle and not one above and one below.
I was hoping this lock was compatible with all UK doors but having installed my own I cant see how theres provision for both screw holes being below the handle.
Any advice as to whether this could be made to work or perhaps its a case of just sending it back for a refund as this is a UK door that isnt in fact compatible.
@nstockley Hey there! Not a silly question at all — door compatibility can be tricky, especially with UK door variations.
I took a look through the reference info available, and unfortunately I don’t see any specific details about the U600 model or its handle screw hole configurations. The knowledge base covers U100, U200, U300, and U50 models, but the U600 isn’t represented here.
From your description, it sounds like the door’s existing handle mounting pattern (both screws below the handle) doesn’t match what the U600 expects — typically one above, one below for proper alignment and torque distribution. Without confirmed specs or adapter options for the U600 specifically, I’d be hesitant to suggest a DIY workaround that could compromise security or function.
You seem to be experiencing an issue with U600 door lock compatibility with your UK door’s handle screw configuration. You can contact customer support for assistance.
This will be more efficient. If you do not have an Aqara Home account, “Please click here” to create a ticket. Apologies for the inconvenience!
They’ll have the U600 technical specs and can confirm whether there’s a mounting plate adapter, or if a return is the better route. Given it’s a gift, probably worth getting clarity before your friend starts drilling
