Hi all, I wanted to share my experience with using the Wyze Camera for a long-term time lapse project. I’ve been documenting the reconstruction of our house after the wildfires, and it’s been an incredible journey to capture every step of the process. The Setup I mounted the Wyze Camera on my balcony, overlooking the construction site. My main goals were: - Interval Shots: Capture one photo every 5-6 minutes during daylight hours to avoid long gaps at night or on weekends. - Live-Stream: Have the option to stream the progress in real-time to a website. - Weather Resistance: Protect the camera from rain, as we do get some winter showers here. I decided to place the camera in a simple, weatherproof box with an open side. It’s been working perfectly so far! Integration with Home Assistant I integrated the Wyze Camera with Home Assistant to automate the time lapse and stream. It’s amazing how seamlessly everything works together. I set up a simple script to trigger the camera at specific intervals and store the images in a dedicated folder. Challenges and Solutions One thing I was worried about was battery life, especially since the camera would be running almost continuously. However, I found that using a power adapter solved this issue completely. The camera has been running non-stop for months without any problems. Tips for Others If you’re considering a similar project, here are a few tips: 1. Test the Setup: Before committing to a long-term project, test the camera settings and intervals to ensure everything works smoothly. 2. Protect Your Equipment: Invest in a good weatherproof housing to extend the life of your camera. 3. Use Home Assistant for Automation: It’s incredibly versatile and makes managing long-term projects much easier. Results So Far It’s been incredibly rewarding to see the progress of the reconstruction in time-lapse. I’m planning to compile all the footage into a final video once the project is complete. It’s not just a record of the work done but also a visual story of resilience and hard work. I’d love to hear if anyone else has undertaken a similar project or has tips to share! Happy building and documenting! ![]()
