Looking to replace my Ring outdoor camera is Aqara a good option?
Hi everyone! I’m quite new to Aqara products and Apple Home. I’m looking for a good battery-powered camera to replace my current outdoor one. Maybe someone has had a good experience with one and can recommend something?
I heard Aqara might be releasing one, but the information I found is quite old.
@breakyourwalls Welcome to the Aqara ecosystem! Great choice exploring options that work well with Apple Home.
Unfortunately, Aqara doesn’t currently have a battery-powered outdoor camera available. The good news? An outdoor camera is in the pipeline and expected in 2025, though details are still under wraps at this stage.
For now, if you’re open to a wired outdoor solution, Aqara’s camera lineup leans heavily into HomeKit Secure Video and solid ecosystem integration—so once that battery model drops, it should slot nicely into your Apple Home setup.
If you need something immediately, you might want to look at other HomeKit-compatible battery options temporarily, or consider whether you can run power to a wired Aqara camera. Would love to hear what direction you end up going
Thanks for the reply, but it’s almost 2027…
@breakyourwalls I totally get the frustration—waiting on product timelines can feel like forever, especially when you’re ready to upgrade now! :sweat_smile:
Just to clarify the current state of things: the Camera Hub G5 Pro did officially launch in February 2025 as Aqara’s outdoor camera option, but it’s a wired solution (Wi-Fi or PoE), not battery-powered[“content_id”:9"]. So if you’re specifically needing something cordless, that gap unfortunately still exists in Aqara’s lineup.
For your Apple Home setup, the G5 Pro does tick a lot of boxes—HomeKit Secure Video, built-in Zigbee hub, Matter Controller, Thread Border Router—but only if you can run power to it[“content_id”:1"].
Since a battery-powered Aqara outdoor cam hasn’t materialized yet and your timeline is getting tight, it might be worth weighing whether:
  • You can make a wired install work (even temporarily)
  • A hybrid approach with another HomeKit-compatible battery cam for now, then re-evaluate if Aqara fills that gap later
What’s your flexibility on power sources? Sometimes a small solar panel + wired cam setup can bridge the gap if outdoor outlets are tricky.
