Hi everyone, I have a vibration sensor, and it keeps losing its connection. I always have to bring it back inside to re-pair it with the base, then take it back outside to my mailbox. After that, it works for a few days or weeks, and then it loses the connection again. This is already the third time I’ve lost the connection. Has anyone had similar problems? Does anyone have a solution? Thanks, Tobias.
Have you tried to put it closer to the base station for like a few days to see if it fixes it becouse to me it looks like a weak signal it coud be that the signal is strong enough to maintain a connection but to weak to reconnect to it when it loses it
Otherwise check that everyting is upto date
And do you have multiple vibration sensors otherwise you coud switch the 2 and see if the issue is at the same location with diffrent sensor or that the one sensor is defect
Hope it helps
i will get an aqara plug, to test if its the distance. But if i pair it new at the station it worked for a few days and suddenly the connection is lost.
Hi there and welcome to the forum.If you have an Aqara smart plug place in between the hub and the sensor as that will be the bridge between the sensor and hub more you need to reset it after you place the plug in between so the sensor connect tru the smart plug to hub otherwise will work as before loosing connectivity with the hub.and check signal after that as it should see excellent once is connected tru the plug and if is not after resetting it then keep trying a few times and also press his button after pairing it sometimes this make it to connect tru the bridge (smart plug) and not directly to the hub.
thanks i will try, once the plug arrived
Hi, I’ve just bought a Sonoff S60ZBTPF smart plug and connected it to my G410. However, the Aqara app shows the manufacturer as Aqara, and the power monitoring feature isn’t available either.
Well, you need an Aqara wired zigbee device to extend the network… I didn’t knew it’s possible with a third party power plug
But now my vibration sensor has excellent signal quality, so the Sonoff Plug probably works as a repeater—it’s just that its functionality is limited.
Oh good to hear! Good this Zigbee network was able to extend by this plug too ![]()
