Hello everyone, I’m facing an issue with my Lutron Caseta setup after a power outage. I’ve been successfully using Home Assistant with my Lutron Caseta hub, but after unplugging both the hub and my Raspberry Pi, I can’t seem to get the Lutron lights to work through Home Assistant. They still function through the Lutron app and Google Home, so it’s definitely a Home Assistant problem. Looking at the logs, I see an error that suggests the IP address for the Caseta hub might have changed, but I have it set as a static IP in my router. I’ve confirmed the IP hasn’t changed, but I’m still stuck. Has anyone else encountered this issue? I’ve tried restarting Home Assistant several times without success. Any advice would be greatly appreciated!
