M100 fails to connect to AIMesh node, when it connected to main router fine
M100 fails to connect to AIMesh node, when it connected to main router fine.
I’ve tried resetting completely (tap 10 times) and still no luck.
I’ve also tried a different 2.4Ghz network in the property, but it still fails while trying to connect to WiFi (unknown error appears).
Hello, check if you have automatic switching 2.4 ↔ 5 GHz enabled. If so, then try disabling it and giving only 2.4.
I also manually add permission in the router. There was a case where the router blocked the gateway as third-party equipment.
No, it was because I had bound it to the main router, so it wouldn’t install on one of the mesh routers. Once I’d unbound it, I could then add it to the mesh router.
