M3 Hub, disconnects several times a day
Several times a day, the hub goes offline. The WiFi signal is between -60 and -65. it’s been fine for a year.
Any ideas?
Hey there.check the power source as usually that could make the M3 go offline so many times this is you have an stable WiFi
Hello.
Also, check the power cord—I’ve had this happen before. It looked brand new, but the contact inside the plug was poor. The voltage drops when the gateway is under load, causing it to reboot.
