One of my curtain drivers has gone offline so I have tried to add it back to the M3 hub but it fails every time. I then tried to bind it to my G3 camera hub and it worked fine.
Anyone else had an issue with binding to the M3, all of a sudden?
Funnily enough I got the U600 door lock yesterday and it would not bind to the M3 and figured it was an issue with the lock. Sent it back but I am now thinking there is an issue with the hub?
Anyone else had this issue and if so how did you solve it? I have tried the old unplug it and plug it back in.
Hey there.did you check if the “Accidental removal protection is ON”?if you go to Aqara home app and enter on the M3 hub got to the bottom of that page and check it.if is off then I suggest an factory reset of M3 see if that fix your issue
Since the curtain driver can bind to your G3, I’d note the M3 firmware, Aqara Home app version, and exact error before considering a factory reset. Does the M3 fail to discover the driver, or does it find it and fail at the final binding step? That distinction may help support separate pairing trouble from an app or account issue.
