Hello everyone, I’m facing a perplexing issue with my Home Assistant setup. I’ve noticed that on two Raspberry Pi devices and a 16.04 Ubuntu machine, the Home Assistant service occasionally exits with the error Main process exited, code=killed, status=7/BUS. This happens whether I’m running a fresh installation or using an existing configuration. It’s quite puzzling as it occurs both when I manually start the service and at random times throughout the day.
I’ve tried troubleshooting by checking system logs and ensuring all dependencies are up to date, but nothing seems to resolve the issue. I’m wondering if anyone else has encountered this problem or has any insights into what might be causing it. Any suggestions or advice would be greatly appreciated! Let’s hope we can figure this out together. ![]()
