Make a LIDAR Rain Sensor!
I’m sure there’s LOTS of other dog owners out there that are regularly caught in the rain as their weather apps say that it’s not raining (but it is) - and you often can’t see the drops looking out your window. We need a LIDAR rain sensor that we could mount to our patio/balcony supports that would tell us in the Home app whether it’s raining outside or not (want to make it extra fancy, add a barometer and thermometer if you like) :slight_smile: You could make it a complete weather station if you make it inexpensive enough. :).
A weather station would be nice
Yup I already mention that to Aqara and in the mean time I made my own rain sensor from Aqara water leak sensor and for now works perfectly at least to lower my blinds
Hey there! As a fellow dog owner, I totally get the struggle of stepping outside only to get soaked by surprise rain. A dedicated outdoor weather station or optical rain gauge from Aqara would be absolutely amazing, but until they decide to make one, the community has a really solid workaround.
You can actually hack the standard Aqara Water Leak Sensor to act as a highly sensitive rain gauge. The sensor triggers when the two hex screws on the bottom are bridged by moisture. You just attach some simple wires to those screws and connect them to a cheap conductive rain detection plate or an optical rain sensor board mounted on your balcony. Keep the Aqara sensor itself tucked inside a waterproof project box, and the second a raindrop hits your outdoor plate, it instantly registers in the Aqara and Apple Home apps.
From there, you can easily set up an automation to flash your smart lights blue or send an alert to your phone before you head out the door with the leash. It is not quite a fancy LIDAR weather station, but it is inexpensive, incredibly responsive, and keeps you and the pup dry. Let me know if you want some links to the wiring guides!
