I am planning to purchase a U400. My question is this: I currently leave my door unlocked after I enter, and want to be able to do that with a U400. I know there is a setting to allow that. However, my understanding is that currently, when I would leave and want to lock manually from outside, I can press a lock button, and that is it. Since I want to prevent malicious locking of my door by unauthorized persons, is there currently an option to enter a code (or use fingerprint, watch etc,) to lock the door from the exterior rather than pressing a button accessible to anyone?
If not, is that something that might be added to a future firmware update?
No, currently there is no such option.
But I’m curious - why would it be safer to make locking harder? The whole point of the lock is to make sure nobody unwanted enters your house. So it’s better to lock the door more often than not enough.
With traditional locks, we choose to leave the door unlocked because using the keys every time is not always convenient. But generally, the door should be locked by default if you want your home to be safe.
And your door should be locked even when you’re home - there have been cases of robberies with the residents still present at home. So better safe than sorry!
Personally I even use the auto-lock - the door locks every time I close it. It’s way safer, because I won’t forget to lock it. And the great thing about smart locks is that they’re convenient. You don’t need to find the keys and use them to unlock (which is especially inconvenient when your hands are full). You just put your finger and the door unlocks, or even better, with the U400 you don’t even have to do anything. The UWB is used to detect that you’re at the door and voila! A handless unlock.
Very convenient and much safer than leaving the door unlocked.
Oh - and another thing. If you’re inside and someone locks you from the outside, you don’t even need the code or fingerprint, or an iPhone close to open it. You just turn the knob. It’s impossible to lock somebody in.
Thank you.
I live in a secure building so I can leave front door unlocked when home. But the current ability to touch wake it up the key pad, and then tap the lock icon/button on the exterior panel should be fine.
