MARS Tech compatibility – Aqara Dimmer Switch H2 EU & Bulb T2 RGB
I have an Aqara Dimmer Switch H2 EU (No Neutral) and an Aqara LED Bulb T2 RGB, both connected via Zigbee to an Aqara Hub M3. Both devices are running the latest firmware and are installed on the same electrical circuit.
I would like to know whether the Dimmer Switch H2 EU supports MARS Tech when used with the Bulb T2 RGB.
More specifically, can the switch keep the bulb permanently powered while controlling it through Zigbee, allowing:
  • On/Off control,
  • Brightness adjustment using the rotary dial,
  • Proper synchronization between the physical switch and the bulb state,
without cutting power to the bulb?
Hope someone can help :wink:
@awax_38 Hi there! Thanks for reaching out with this detailed question. It’s great to see you diving into the specifics of MARS Tech and Zigbee automation!
Based on the current product specifications, the Aqara Dimmer Switch H2 EU does not support MARS Tech or wired smart light integration.
Here is the breakdown:
  1. No Wired Smart Light Support: The Aqara Dimmer Switch H2 EU is designed to control standard loads (like incandescent, halogen, or dimmable LED/ELV fixtures) via physical dimming. It does not support a wired connection to smart lights, such as the Aqara LED Bulb T2 RGB.
  2. Risk of Damage: Using the H2 Dimmer with smart lights that are already connected to the network can potentially cause damage to either the switch or the smart bulb.
  3. MARS Tech Requirements: MARS Tech functionality specifically requires Aqara smart lights (like the T1M or other compatible Zigbee bulbs) and is typically associated with the Light Switch H2 series (e.g., Light Switch H2 EU or Horizontal), not the Dimmer Switch H2 EU[“content_id”:5"].
Since the Dimmer Switch H2 EU cuts power or adjusts phase for traditional bulbs, it cannot maintain the “permanently powered” state required for MARS Tech with a smart bulb like the T2 RGB. The T2 RGB bulb needs to stay powered to receive Zigbee commands for color and brightness changes, which the H2 Dimmer is not designed to provide in a smart-light-compatible way.
You seem to be experiencing an issue with compatibility between the Dimmer Switch H2 EU and the Aqara LED Bulb T2 RGB for MARS Tech functionality. You can contact customer support for assistance.
