I’m slowly getting more and more matter devices coming from Zigbee, One thing i learned is that cheap Zigbee routers only connect to 5 others.
Is this the same with matter and thread?
Hi there.they all work in the same way but you have mention zigbee routers now I am not so sure how this are but to make an good zigbee mesh you need zigbee bridges from the same brand like Aqara and Aqara have bulbs,LED strip,smart plugs and smart switches(with neutral line)that are zigbee bridges but batterie devices like sensors are not bridges this happens on thread mesh too same thing you need thread border routers witch are smart plugs or other powered devices witch make the bridge between the main controller and others thread devices.
Looking at my Z2M Map i can see the cheap aliexpress Zigbee devices only ever link to 5 devices as if they have a small address table.
But i’m new to matter and not wanting to fall in to the same boat
Here check this thread were explain better how all works
Ahhh perfect, thanks for that.
