I recently decided to integrate my plugin-hybrid car into my smart home system using the Shelly Plug. The idea was to leverage the excess solar power generated by my PV system to charge my car. The charging cable I’m using operates at 230V/16A, which, according to the Shelly Plug’s specifications, should be within its capacity. However, I encountered an unexpected issue: the Shelly Plug has a fixed maximum power limit of 3500W. This means that even though my setup theoretically allows for 3680W, the plug triggers an overload when this threshold is reached.
I’ve reached out to the manufacturer and community forums, but so far, there hasn’t been a definitive solution. Some users suggested adjusting the firmware or using external power management tools, but these options seem a bit too technical for my current setup.
On a more positive note, I’ve discovered some innovative workarounds, such as using a smart meter to monitor energy consumption in real-time and adjust charging schedules accordingly. This approach not only helps stay within the Shelly Plug’s limits but also optimizes energy usage during peak solar production.
I’m curious to hear if anyone else has faced similar challenges or has found a more seamless solution. Maybe there’s a way to tweak the Shelly Plug’s settings or integrate it with other smart home devices to bypass this limitation. I’m open to suggestions and would love to collaborate on finding a more efficient charging solution.
In the meantime, I’m exploring alternative smart plugs that offer more flexible power management features. It’s a bit of a setback, but it’s also a great opportunity to learn more about energy optimization and smart home integration. I’ll keep the community updated on my progress and any breakthroughs I make.
