Hey everyone, I wanted to share my recent experience with the SwitchBot Hub Plus and how it transformed my smart home setup. I recently picked up a budget-friendly 32” Fire TV Edition Toshiba TV for our guest room, but it came with a caveat—no voice control for turning it on or off. This was a bit frustrating since I wanted seamless integration with my existing smart home ecosystem.
After some research, I discovered that the SwitchBot Hub Plus could solve this issue using its built-in IR blaster. I was pleasantly surprised by how straightforward the setup was. Here’s a quick rundown of what I did:
- Added the TV to the SwitchBot App: This step was pretty intuitive. I just followed the on-screen instructions to pair the TV with the SwitchBot Hub.
- Integrated with SmartThings: The SwitchBot app works seamlessly with SmartThings. I created a toggle scene in the SwitchBot app and linked it to Alexa. Now, I can turn the TV on and off with a simple voice command!
- No Custom Coding Needed: One of the best things about this setup is that it doesn’t require any coding or third-party servers. Everything is handled through the SwitchBot and SmartThings apps.
This solution has been a lifesaver for me. It not only solved the TV issue but also gave me confidence in using SwitchBot for other home automation projects. Plus, the fact that it’s compatible with Alexa, Google Home, and IFTTT makes it incredibly versatile.
If you’re looking for an affordable and effective way to add voice control to your devices, I highly recommend checking out the SwitchBot Hub Mini or Hub Plus. They’re both compact, easy to set up, and come with a variety of integration options.
Let me know if anyone has questions or needs help setting this up! ![]()
