Hi everyone, I’ve been having some trouble setting up automations with my Meross thermostats using HomeKit. I have three of them installed, and while I can control the temperature and functions directly through HomeKit, I’m unable to get the automations to work properly. When I test the automation, nothing happens, which is quite frustrating. I’ve followed the setup instructions carefully, linking the thermostats through the Meross app and then adding them to HomeKit. However, it seems that automations aren’t supported in the same way as other HomeKit devices. I’ve checked with Eve, and there are no automations in the Meross app either. I’m wondering if anyone else has experienced this issue or has found a workaround. I’ve reached out to Meross support, but I’m hoping someone here might have some insight or suggestions. Thanks in advance for your help!
