I wish there was a way to have a mesh network of mmWave sensors because its hard to cover all parts of a room that’s not a perfect square!
Why not setup 2 sensors on each side and just divide the room using the mapping? Set the edge of the room halfway on both sensors.
Then make automations that you trigger by one or both of the sensors?
It’s a good idea. But should it be 100 efficient? Can’t one order overlap with the other? The partner’s idea is very good, it would be great to be able to link more than one and that they will act as if it were one, to be able to solve those problems.
I agree that linking them is a fine idea, but for now I would suggest set up 2.
And overlap wouldn’t be a problem as you could put in your routine that if you have movement in either one it should do something.
