Migrating a Zephyr Project from Child/Parent Build System to Sysbuild: First Steps and Questions
I’m currently in the process of migrating my Zephyr project from the traditional child/parent build system to the newer sysbuild system. While I’ve found the transition to be a bit challenging, I’m excited about the potential benefits that sysbuild offers, such as improved scalability and maintainability.
Current Project Structure
My current project structure is as follows:
application
├── CMakeLists.txt
├── prj.conf
├── boards
│ └── arm
│ ├── board_A
│ └── board_B
├── child_image
│ └── mcuboot
│ ├── prj.conf
│ └── boards
│ ├── board_A.conf
│ └── board_B.conf
├── keys
│ ├── board_A.pem
│ └── board_B.pem
└── src
Initial Steps
From what I understand, the first step in migrating to sysbuild is to remove the child_image folder and replace it with a sysbuild folder. Additionally, a sysbuild.conf file needs to be created. I’ve followed the steps outlined in a helpful post I found, which provided a good foundation for understanding the migration process.
Modified Project Structure
After making the necessary changes, my project structure now looks like this:
application
├── CMakeLists.txt
├── prj.conf
├── sysbuild.conf
├── boards
│ └── arm
│ ├── board_A
│ └── board_B
├── sysbuild
│ └── mcuboot
│ ├── prj.conf
│ └── boards
│ ├── board_A.conf
│ └── board_B.conf
├── keys
│ ├── board_A.pem
│ └── board_B.pem
└── src
Configuration Files
Here’s a brief overview of the key configuration files I’ve modified:
CMakeLists.txt
cmake
SPDX-License-Identifier: Apache-2.0
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(gravity_sensor)
target_sources(app PRIVATE
src/main.c
src/app.c
src/status_led.c
src/ble_connection.c
src/icm20948.c
src/error_managing.c
src/memory.c
src/bsm.c
prj.conf
conf
CONFIG_LOG=y
CONFIG_LOG_MAX_LEVEL=2
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
CONFIG_USB_MASS_STORAGE_LOG_LEVEL_ERR=y
CONFIG_RING_BUFFER=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_REBOOT=y
printf floats support
CONFIG_CBPRINTF_LIBC_SUBSTS=y
CONFIG_CBPRINTF_FP_SUPPORT=y
time library support
CONFIG_NEWLIB_LIBC=y
CONFIG_POSIX_API=y
SOC’s peripherals configuration
CONFIG_GPIO=y
CONFIG_PWM=y
CONFIG_LED=y
CONFIG_I2C=y
CONFIG_NRFX_SPIM0=y
CONFIG_NRFX_TIMER1=y
CONFIG_NRFX_PPI=y
NVS memory configuration
CONFIG_NVS=y
Flash memory support configuration
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_FLASH_MAP=y
BLE configuration
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME=“Gravity Sensor”
CONFIG_BT_DEVICE_APPEARANCE=1345
CONFIG_BT_MAX_CONN=1
CONFIG_BT_LL_SOFTDEVICE=y
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_ACL_TX_SIZE=502
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_RX_BUFFERS=2
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=4000000
CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_CTLR_CONN_RSSI=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=6
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=80
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
DFU configuration
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_MCUMGR=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_FLASH=y
CONFIG_THREAD_MONITOR=y
CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
CONFIG_STATS=y
CONFIG_STATS_NAMES=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_STAT=y
CONFIG_LOG=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_SERIAL=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_CONSOLE=y
CONFIG_MCUMGR_TRANSPORT_UART=y
CONFIG_BASE64=y
sysbuild.conf
conf
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n
SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE=“path/to/key.pem”
Challenges Encountered
Despite these modifications, I’m still encountering an error during the build process. The error message indicates an issue with the CMake configuration, specifically with the list GET command receiving an empty list. I’m not entirely sure what’s causing this, but I suspect it might be related to how the sysbuild configuration is being interpreted.
Questions
- Sysbuild Configuration: What exactly should be included in the
sysbuildfolder and thesysbuild.conffile? Are there any specific guidelines or best practices for setting these up? - Project Configuration: Are there any changes I need to make to the existing
prj.confandCMakeLists.txtfiles to ensure compatibility with the sysbuild system? - Error Resolution: How can I troubleshoot and resolve the CMake error I’m encountering? Are there any common pitfalls or known issues with the sysbuild migration process?
Seeking Assistance
I’m hoping the community can provide some guidance or insights into these questions. If anyone has experience with migrating projects to the sysbuild system, I’d greatly appreciate any tips, tricks, or resources you can share.
Looking forward to hearing from you all!
