I recently made the switch from Stringify to Home Assistant, and it’s been quite the journey! While Stringify worked well for my basic automations, the shutdown announcement left me in a bit of a bind. I wanted to replicate my existing setup, which involved using a Google Calendar to trigger bedroom lights based on wake-up times for me, my wife, and the kids. The automation would adjust the brightness and color after specific intervals, creating a smooth wake-up experience.
After some research, I discovered that Home Assistant could handle this with the Google Calendar integration and a bit of YAML scripting. However, I also explored Node-RED as an alternative for more complex flows. I found that combining both tools gave me the flexibility I needed.
Another challenge I faced was integrating my Wyze Cam v3, which had connectivity issues. Replacing the power brick fixed the problem, but it highlighted the importance of checking hardware when troubleshooting. I also looked into using OpenHAB for a more comprehensive automation setup, especially for devices like my Extron Matrix AV Switcher, which relies on Telnet commands.
One of the most rewarding parts of this transition has been learning how to write custom rules and bindings. It’s been a steep learning curve, but seeing everything come together has been incredibly satisfying. I’d love to hear from others who have successfully integrated multiple devices or migrated from other platforms—what tips or tricks did you find most helpful?
