I’m currently in the process of migrating all my smart home devices from various ecosystems to Home Assistant. It’s been an exciting journey, but I have a few questions and concerns that I’d love to get some advice on.
First, I’ve been using multiple platforms like SmartLife, SmartThings, and Yeelight for different devices. I’m wondering if I should completely disconnect these accounts before setting up Home Assistant, or if it’s better to keep them connected initially and then disconnect them later. I’m not entirely sure how this will affect compatibility or data synchronization.
Another issue I’m facing is related to my Zigbee setup. I recently purchased a CC2531 USB sniffer to use with Zigbee2MQTT. When I check the serial devices, I see multiple options like /dev/ttyAMA0, /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193B07A7-if00, and /dev/ttyACM0. I’m not entirely sure which one I should use in the Zigbee2MQTT configuration. I’ve tried a few different ports, but I’m still getting errors. Any guidance on this would be greatly appreciated!
I’m also experimenting with creating custom templates for my HVAC system. I’ve set up a blueprint that uses a template to calculate the next scheduled time based on the current time and some input variables. However, when I test it in the blueprint, it returns none, even though it works perfectly in the template tester. I’m not sure why this discrepancy is happening. Is there something I’m missing in the blueprint configuration?
Overall, I’m really excited about the potential of Home Assistant to unify all my devices and automate my home more effectively. I’m just hoping to get some clarity on these issues so I can proceed smoothly with the migration. If anyone has experienced similar challenges or has tips to share, I’d love to hear from you!
