Migrating from Openhab to Homey: A Smooth Transition with Tips and Tricks
After four years and thousands of hours with Openhab, I decided to switch to Homey over the weekend. The decision was partly due to recurring SD-card issues, and I must say, I’m thoroughly impressed with Homey’s ease of use and sleek design. However, the transition hasn’t been entirely seamless, especially when it comes to integrating my existing sensors and devices that rely on Modbus and web APIs.
I’ve been experimenting with MQTT as a potential solution, using a Raspberry Pi to convert the Modbus data. While this approach shows promise, I’m still figuring out the best way to integrate these sensors into different rooms without cluttering my flows. Does the MQTT client support this setup effectively? Or should I consider the Home Assistant integration within MQTT Hub? I’m also exploring whether converting the data through Node-RED or Home Assistant could simplify the process.
Another consideration is whether I need to invest in more Z-Wave devices to fill the gaps. I’m curious to hear if others have successfully navigated similar transitions and what strategies they employed. Whether it’s through MQTT, direct API integration, or a combination of tools, I’m eager to find the most efficient and scalable solution for my setup.
In the meantime, I’m thoroughly enjoying Homey’s user-friendly interface and the peace of mind that comes with a more reliable system. It’s a learning curve, but every challenge brings a new opportunity to refine my smart home setup. Thanks to this amazing community for all the support and inspiration!
