Hey everyone, I wanted to share my recent experience migrating from ZHA to Z2M. It’s been quite a journey, and I thought I’d document it here in case others are considering the same move. ![]()
So, I’ve been using ZHA for a while now, with a mix of Aqara sensors and other devices. It’s been reliable, but I’ve heard great things about Z2M’s performance and ease of use. Plus, I’ve got this new Sonoff SB 3.0 stick that I wanted to put to good use. The challenge was to switch over without disrupting my existing setup too much. ![]()
First off, I made a detailed spreadsheet of all my devices—names, entity IDs, and their roles in automations. This was crucial because I knew I’d have to rename some entities in Z2M to keep things consistent. The big question was: Do I need to remove ZHA entirely before adding Z2M? From what I gather, it’s not strictly necessary, but it might simplify things. I decided to go the safe route and disable ZHA first, just to avoid any conflicts. ![]()
The process itself wasn’t too bad. I followed some tips from the community, like keeping the same entity names where possible and using Z2M’s naming conventions where I couldn’t. It was a bit tedious, but having that spreadsheet really helped. I also learned that not all devices might be compatible out of the box, so it’s good to check the Z2M documentation or forums for any specific workarounds. ![]()
One thing that surprised me was how much smoother the setup felt with Z2M. The device pairing was quicker, and the integration with Home Assistant seemed more seamless. I’m definitely noticing better responsiveness from my sensors now. ![]()
I’d like to give a shoutout to everyone in the community who shared their experiences and tips. It made this transition much less daunting than I initially feared. If anyone else is thinking about making the switch, I’d say go for it, but take your time and plan it out. You’ll thank yourself later! ![]()
Looking forward to hearing about others’ experiences and any additional tips they might have. Let’s keep the learning going! ![]()
