I’ve always been fascinated by the world of smart homes, and recently, I decided to take my setup to the next level. After years of running my Home Assistant instance on a Raspberry Pi 3B+, I decided it was time for an upgrade. My goal was to migrate to a more robust system that could handle not just Home Assistant but also other projects I had in mind. Enter Proxmox Virtual Environment—a powerful platform that promised flexibility and scalability.
The Setup
Before diving into the migration, I wanted to ensure I had the right hardware. I opted for a Dell MiniPC equipped with an Intel 8500T processor, 16GB of RAM, and a 1TB Samsung NVMe SSD. The decision to go with Proxmox was driven by the stability issues I experienced with the Raspberry Pi, despite it running smoothly once the new hardware was in place.
The Migration Process
The first step was creating a backup of my existing Home Assistant instance. The process was straightforward, and the backup itself was only around 50MB, which made the transition less daunting. I then set up Proxmox on my Dell MiniPC, configuring it to host multiple virtual machines.
One of the challenges I anticipated was ensuring that my USB devices, including the Home Assistant SkyConnect and Homematic IP RF USB Stick, would work seamlessly in the new environment. I discovered that Proxmox allows for USB passthrough, which meant I could directly connect these devices to the virtual machine hosting Home Assistant without any issues.
Another consideration was the Bluetooth functionality from the Raspberry Pi. I found that installing the necessary Bluetooth drivers and services on the Proxmox host and then passing them through to the Home Assistant VM was essential. This required a bit of trial and error, but with some research, I managed to get everything up and running smoothly.
Lessons Learned
- Hardware Sizing: For a mid-level installation with Zigbee, Z-Wave, and Wi-Fi devices, the Dell MiniPC proved to be more than capable. It handles all my current devices without any noticeable lag.
- USB Passthrough: Configuring USB devices in Proxmox was a bit tricky at first, but the documentation and community forums were invaluable.
- Backup and Restore: Ensuring a solid backup before migration was crucial. It gave me peace of mind knowing that I could restore my setup if anything went wrong.
Migrating Home Assistant to Proxmox has been a rewarding experience. The system is now more stable, scalable, and future-proof. I’m excited to explore the potential of running additional services on the same host, all while keeping my smart home setup intact. If you’re considering a similar migration, I’d highly recommend exploring Proxmox—it’s a fantastic platform for home automation enthusiasts looking to expand their horizons.
Happy automating! ![]()
