Mini switch automations will not save to Apple home
I bound a mini switch T1 to an M3 hub in Apple home. Aqara app registers presses on the mini switch. Apple home saw the switch and I was able to rename and move the mini switch to the correct room. But, when I tried to record an action to a button press it would not save. I was able to create the actions within the single press action. But it would not save. Anybody have an idea what is wrong? I have four other buttons that are working.
Hi. What exactly do you mean by “record an action”?
Or what exactly did you set up in the Apple Home app?
Hi, Apple Home automatically deletes an automation if the device disappears from Apple Home (or is re-added).
Apple Home might “think” the device was re-added if something goes wrong when it doesn’t sync your home data properly and the hub (like HomePod) was restarted or changed (if you have multiple HomePods, they may periodically change which one is the “smart home hub”).
Does your automation disappear immediately? Or after a while? Can you show us the steps/screenshots with what you do to configure the automation?
