Mini Switch stopped Controlling Siri Shortcuts - Can't access Single, Double or Long Press setup
Short version… what happened to the Single, Double and Long press setup in Aqara Home? Now it’s only Automation and Scene setup.
Mini Switch and Aqara hub firmware are up-to-date.
I’ve been using a single Mini Switch to run two Siri Shortcuts. Single press on the mini switch triggers a shortcut to run a scene in my master bath. Turn on the lighted mirror, turn on high hats, shower niche light. A long press turned everything off (a little more complication in the shortcut with time of day If/Then commands).
This has worked flawlessly for for two years. It stopped unexpectedly a few days ago.
When I access the Mini Switch in the Aqara Home app I no longer see the options for Single, Double and Long press. Now it’s only Automation and Scene setup.
I still have the Siri Shortcuts but can’t figure out how to set the Mini Switch to trigger them as they used to?
Hello, welcome to the forum. Maybe your mini switch needs a battery replacement. The second way is to reinstall the mini switch.
These settings are only available in AUTOMATIONS…
Exactly! And maybe a reinstall might help as @gafich10 mentioned before.
If it doesn’t help , please provide us some screenshots
