Minoston Z-Wave Smart Plug 2 Channel Integration Issues
Hello everyone, I’ve recently added the Minoston Z-Wave Smart Plug 2 Channel to my Hubitat setup, and while it’s a great device, I’m running into some integration issues that I’m hoping you can help me with.
After pairing, the device shows up correctly, and I can control each channel individually. However, there’s an inconsistency in how the switch states update. When I toggle the parent device, only the left channel responds, and the switch status doesn’t update unless I manually refresh the dashboard. This is a bit frustrating, especially when trying to automate my home setup.
I’ve tried renaming the channels and adjusting the device type to the Zooz dual plug, but the issue persists. Additionally, when adding the device to my dashboard as an outlet, clicking it just shows ‘SENDING’ and doesn’t update the state. I suspect this is due to the state not refreshing properly.
Has anyone else encountered this problem? I’d greatly appreciate any insights or workarounds you might have. I’m really looking forward to getting this device fully functional, and I’m sure with your help, we can figure this out! Thanks in advance for your support. :pray:
