Modbus Configuration for Unelvent Ventilation Systems
After spending some time figuring out the correct setup, I thought it would be helpful to share my experience with configuring Modbus for Unelvent ventilation systems. This guide is based on the Modbus binding version 2 and has been tested with the Domeo 210 FL, though it should work with other versions as well.
Supported Models
Here’s a list of compatible models:
  • Domeo 210 FL
  • Domeo 210 + hygro sensor
  • Domeo 210 constant airflow FL
  • Flexeo 210 FL
  • Flexeo 325 FL
  • Ideo 300 constant airflow
  • Ideo 450 constant pressure
Configuration Steps
  1. Install the Modbus Binding: Ensure the Modbus binding is installed in your system. No additional setup in the paperUI is required.
  2. Download Configuration Files: All necessary files (.items, .sitemap, .things, and transformations) are available on GitHub. The sitemap provided is basic and can be customized based on your specific ventilation model.
  3. Adapt to Your System: Modify the sitemap and other configurations to match your ventilation system’s specifications.
Benefits
This configuration allows for seamless integration of your ventilation system into your smart home setup, enabling real-time monitoring and control directly from your Home Assistant interface. It’s a great way to optimize airflow and maintain indoor air quality efficiently.
If you have any questions or need further assistance, feel free to reach out! Happy configuring! :rocket:
