Modifying Dashboard Headers with Card-Mod: A Step-by-Step Guide
Hey everyone, I’ve been diving into customizing my Home Assistant dashboard lately, and I thought I’d share my journey with you. I recently discovered the card-mod integration, which has opened up a whole new world of possibilities for tailoring my interface to my liking. However, my initial attempt to modify a header card didn’t go as smoothly as I hoped, so I decided to dig deeper and figure out what was going on.
Initially, I tried adding card-mod to my existing YAML configuration for a header card, hoping to change the text color. Here’s what my setup looked like:
yaml
card:
type: markdown
text_only: true
content: Climate
card_mod: null
style: |
ha-card {
–primary-text-color: red;
Unfortunately, despite no errors in the logs, the text color remained unchanged. Frustrated but determined, I started researching and experimenting with different configurations. What I discovered was that the way styles are applied in card-mod can be a bit finicky. After some trial and error, I found that wrapping the style block within a <style> tag made all the difference. Here’s the corrected version that worked for me:
yaml
card:
type: markdown
text_only: true
content: Climate
card_mod: null
style: |
ha-card {
This tweak successfully changed the text color to red, and I couldn’t be happier with the result! It’s a small change, but it makes a big difference in personalizing my dashboard.
If you’re looking to customize your headers or other cards, I highly recommend exploring the card-mod integration. It’s a powerful tool that can really help you make your Home Assistant setup feel uniquely yours. Let me know if you have any questions or tips of your own—I’m always happy to help!
