I’ve recently added a Moes Smart Knob to my setup and it’s been a fun project to integrate it into my existing smart home ecosystem. The knob itself is a great device for controlling various aspects of my home, but I wanted to take it a step further by creating a custom automation that responds not just to the direction of the turn, but also to the step_size and step_mode values it provides.
The Challenge
When using the knob, it logs events with parameters like step_mode (indicating direction) and step_size (indicating how far it was turned). However, the existing Blueprints I found only respond to the direction without considering the step_size. This limited the potential for more nuanced automation, like adjusting the volume of a media player or dimming lights based on how far the knob was turned.
My Solution
After some research and experimentation, I managed to create an automation that extracts these values and uses them to trigger specific actions. Here’s a breakdown of how I did it:
- Event Listening: I set up the automation to listen for the
Turn Knob Stepevent specifically. - Variable Extraction: Using the event data, I extracted
step_modeandstep_sizeinto variables. - Conditional Actions: Based on the values of these variables, I created conditional statements to trigger different actions. For example, turning the knob clockwise (
step_mode: 0) could increase the brightness of my lights, while turning it counterclockwise (step_mode: 1) could decrease it. - Testing and Fine-Tuning: I tested the automation extensively to ensure it responded correctly to different
step_sizevalues and adjusted the actions accordingly.
Results
The outcome has been fantastic! Now, I can:
- Adjust Lighting: Turn the knob a little for a subtle dim or a lot for a dramatic change.
- Control Volume: Use the knob to adjust the volume of my media player with precision.
- Scene Activation: Set up different scenes based on how the knob is turned, creating a more immersive experience.
Looking Forward
I’m really excited about the possibilities this opens up. The Moes Smart Knob is proving to be a versatile tool, and being able to leverage its full range of inputs has taken my automation to the next level. I’d love to hear how others are using similar devices or have tackled similar challenges!
Let’s keep the ideas flowing! ![]()
