Monitoring and Controlling Technicolor TC4400 with Home Assistant
Hi everyone! I’ve been trying to figure out how to monitor and control my Technicolor TC4400 modem using Home Assistant. It’s been a bit of a challenge, but I wanted to share my journey and hopefully get some feedback or tips from the community.
So, the issue I’m facing is that my modem occasionally loses its connection, and I have to manually reboot it to get back online. This is pretty inconvenient, especially when I’m not home. I thought, why not integrate this into Home Assistant so I can monitor the connection status and even trigger a reboot if needed?
After some research, I came across a few ideas. One approach is to use the modem’s built-in API to check its status and send reboot commands. Another option is to use a shell command to ping the modem and trigger a reboot if it doesn’t respond. I’m leaning towards the API method since it seems more reliable, but I’m not entirely sure how to set it up.
I found a few examples online where people have successfully used Home Assistant to monitor their modems. They mentioned using sensors to track the connection status and automations to trigger reboots. I’m thinking of setting up a sensor that checks the modem’s status every few minutes and an automation that sends a reboot command if it detects a problem.
However, I’m a bit stuck on how to securely access the modem’s API from Home Assistant. I know I need to configure the modem to allow remote access, but I’m not sure about the exact settings. I also need to figure out how to handle authentication since the modem requires a username and password.
If anyone has experience with this or can point me in the right direction, I’d really appreciate it! I’m excited to get this working and would love to share my setup once I have it sorted out. Thanks in advance for any help or advice you can offer!
