Monoprice Motion Sensor Troubleshooting and Solution
I recently encountered an issue with my Monoprice motion sensor, and I wanted to share my experience and solution in case it helps anyone else facing a similar problem.
Initially, I noticed that the sensor wasn’t reporting motion events, despite functioning correctly for temperature readings. After some research and troubleshooting, I discovered that the device type in my hub settings wasn’t correctly configured.
Here’s what I did to resolve the issue:
  1. Device Type Configuration: I changed the device type from a generic Z-Wave motion sensor to the custom device type specifically created for the Monoprice sensor by florianz. This adjustment ensured that the sensor was recognized correctly by the hub.
  2. Resetting the Sensor: I performed a reset by pulling and reinserting the battery. This step is crucial as it clears any cached settings that might interfere with proper functionality.
  3. Rebooting the Hub: After reconfiguring the device type, I rebooted the hub to ensure all changes were applied correctly.
  4. Testing Over Time: I monitored the sensor over several hours to confirm that it was correctly reporting motion events. Thankfully, the issue was resolved, and the sensor now functions as expected.
If you’re experiencing similar issues, I recommend checking your device type settings and ensuring that any custom configurations are correctly applied. Additionally, resetting the sensor and rebooting your hub can often resolve unexpected behavior.
I hope this helps someone else avoid the frustration I initially faced. Happy automating!
