Hey everyone, I wanted to share my experience with setting up a morning automation using my Govee lights. I’ve been really impressed with how seamlessly they integrate into my smart home setup, and I thought I’d walk through how I got everything working smoothly.
So, my goal was to have my bedroom lights gradually brighten at 8 AM every morning, giving me a gentle wake-up call. I’ve heard that this can help with waking up more naturally, and I thought it’d be a nice touch to start my day off right.
First, I needed to figure out how to set up the automation. I use Home Assistant, so I knew I could create a routine there. I went into the automation section and set it to trigger at 8 AM. Then, I added an action to slowly increase the brightness of my Govee light strip over 15 minutes. I chose 15 minutes because I wanted the transition to feel gradual and not too jarring.
The next step was testing. I set the automation to run and waited until 8 AM to see how it worked. To my delight, the lights started dimming up exactly on schedule! The gradual increase was perfect—it felt like the sun was slowly rising, even though it was just my smart lights. I could tell the difference in how I felt waking up compared to my usual abrupt alarm.
I also wanted to add a bit of color to make it more exciting, so I programmed the lights to shift from a warm white to a cooler tone as the morning progressed. This subtle change helps signal to my brain that it’s time to start the day. It’s such a small detail, but it makes a big difference in my morning routine.
One thing I learned during this process was the importance of testing each part of the automation separately before running the whole thing. I initially tried to set everything up at once and ran into a few hiccups, but breaking it down step by step made troubleshooting much easier.
Overall, I’m really happy with how this morning automation turned out. It’s a simple addition, but it’s made a noticeable impact on how I start my day. If you’re thinking about setting up something similar, I’d highly recommend giving it a try—it’s a great way to make the most of your smart lighting setup!
Looking forward to hearing how others have customized their morning routines!
