Morning Automation with Homey: A Smooth Start to the Day
Hello fellow Homey enthusiasts! I wanted to share my experience setting up a morning automation routine using Homey. It’s been a game-changer for how I start my day, and I hope this helps anyone looking to streamline their mornings too!
The Goal:
I wanted my Homey to automatically turn on my TV and living room lights in the mornings when I walk by the motion sensor. However, I noticed that if there was any additional movement after the initial trigger, the automation would repeat, which was a bit annoying. I needed a way to ensure the automation only ran once, even if the motion sensor detected more movement.
The Setup:
Here’s how I configured my flow:
IF:
- Motion sensor detects movement
AND: - Time is between 04:30 and 06:30
THEN: - Start the TV activity (Harmony)
- Turn on the living room lamps
- Turn off the LED ring
The Challenge:
Initially, the automation would restart every time the motion sensor detected movement, even after the initial trigger. This meant my TV and lights would reset every few minutes, which was frustrating.
The Solution:
After some research and experimentation, I realized I needed to add a delay or condition to prevent the automation from repeating. I decided to use a delay in the flow to ensure that once the automation runs, it won’t trigger again for a certain period. This way, even if the motion sensor picks up more movement, the automation won’t restart unless the delay has passed.
The Result:
Now, my mornings are perfectly orchestrated. As I walk by the motion sensor, my TV turns on to my favorite morning show, and the lights dim just right to wake me up gently. The delay ensures everything runs smoothly without any unwanted restarts. It’s like having a personal assistant who knows exactly how I like my mornings!
Tips for Others:
- Experiment with Timing: Play around with the time window and delay settings to find what works best for your routine.
- Use Conditions Wisely: Adding conditions like time constraints can help prevent unintended triggers.
- Test Thoroughly: Before finalizing, test your automation multiple times to ensure it behaves as expected.
I’m thrilled with how this automation has improved my mornings. It’s a small tweak, but it makes a big difference! If anyone has questions or needs help setting up something similar, feel free to reach out. Happy automating! ![]()
