Good morning everyone! I wanted to share a fun project I recently completed that combines several off-the-shelf components with a bit of custom scripting to create a personalized morning alarm system. This setup not only wakes me up but also provides a visual cue of the outside temperature, helping me decide how to dress for the day.
The Components
- Alarm Clock: A Logitech Squeezebox Radio connected to the Logitech Media Server (LMS) running on a Linux VM.
- Custom Script:
lms2mqttlistens for status changes from LMS and publishes notifications as MQTT messages. - Home Automation Controller: OpenHAB subscribes to MQTT messages and triggers rules when the alarm goes off.
- Bedside Lamp: A DIY RGB LED strip controlled by a Wemos D1-Mini board with Tasmota firmware.
How It Works
- When the alarm goes off, the
lms2mqttscript sends an MQTT message to OpenHAB. - OpenHAB retrieves the current temperature from OpenWeatherMap and converts it to a color.
- The bedside lamp turns on and changes color based on the temperature (red for warm, blue for cold).
Setup Details
- The
lms2mqttscript is available on GitHub. - The OpenHAB rules and item definitions are documented here.
- The RGB LED strips were a cost-effective alternative to off-the-shelf smart bulbs.
Why I Love This Project
This project combines my love for DIY electronics with the convenience of smart home automation. It’s a great example of how you can enhance your daily routines with a bit of creativity and open-source tools. Plus, waking up to a color-coded temperature indicator makes mornings a bit more fun!
Tips for Others
- If you’re new to MQTT or OpenHAB, start with simple projects and gradually build up to more complex setups.
- Don’t hesitate to modify existing scripts or rules to fit your needs. The open-source community is all about collaboration and customization.
I hope this post inspires someone to try a similar project or experiment with their existing smart home setup. Let me know if you have any questions or suggestions!
Best regards,
