I’ve always been a fan of waking up to a bright, cozy home, but manually turning on lights and adjusting settings just wasn’t cutting it. That’s why I decided to dive into creating a morning routine automation using my smart home system. Let me share my experience and some tips for anyone looking to do the same!
The Goal:
I wanted my lights to gradually brighten, my coffee machine to start brewing, and my thermostat to adjust to a comfortable temperature—all without lifting a finger. The idea was to create a seamless transition from sleep to wakefulness.
The Process:
- Research: I started by reading through forums and tutorials to understand what was possible with my setup. I discovered that combining smart plugs, smart lights, and a smart thermostat could make this automation a reality.
- Planning: I mapped out the sequence of events: lights dim up over 15 minutes, coffee machine turns on at minute 10, and the thermostat adjusts 5 minutes before the lights finish. This timing ensures everything is ready when I wake up.
- Implementation: Using the app, I created a scene that triggers at 6:30 AM. The lights start with a soft glow and gradually increase in brightness. The coffee machine kicks in halfway through the light cycle, and the thermostat adjusts to 70°F.
The Outcome:
It’s been a game-changer! Waking up to a perfectly prepared home has made my mornings so much more enjoyable. The best part is how customizable this setup is. If I want to adjust the timing or add more devices, it’s just a few taps away.
Tips for Others:- Start Small: Begin with one or two devices and gradually add more as you get comfortable.- Test Thoroughly: Run through the automation a few times before relying on it fully. This helps catch any hiccups in the sequence.- Use the Right Timing: Pay attention to how long each device takes to respond and adjust the automation accordingly.
If anyone has tips or suggestions for improving this setup, I’d love to hear them! Happy automating! ![]()
