Motion Sensor Fan Automation Solution
I recently set up a motion sensor-triggered fan automation in my office and wanted to share my experience in case it helps others facing similar challenges. The goal was to have the fan turn on when I enter the room if the temperature is above 24°C and then turn off after a period of inactivity. While the concept seemed straightforward, getting it to work smoothly took some trial and error.
Initially, I configured the automation using YAML, specifying the motion sensor and temperature condition. However, I encountered an error related to the value template, which was frustrating. After some research, I realized the issue was with how I was referencing the temperature sensor. Once I corrected that, the automation started working as intended.
One thing I learned is the importance of testing each component individually before combining them. For example, ensuring the motion sensor triggers correctly and the temperature sensor reads accurately were crucial steps. I also found that using the delay function helped prevent the fan from turning off immediately if I was still in the room.
This project has been a great learning experience, and I’m excited to explore more automation possibilities around my home. If anyone has tips or alternative approaches, I’d love to hear them!
