Mounting the Homey Pro 2023 vertically is a topic that has sparked some curiosity among users. While the device doesn’t come with pre-drilled holes for vertical mounting, it’s definitely possible to create a custom solution, whether it’s 3D-printed or handmade. I’ve been pondering whether this setup could pose any issues, particularly regarding cooling. The device houses a PI module that tends to run quite hot, and I’m wondering if the orientation might affect the efficiency of the cooling mechanism. My initial thought is that it probably doesn’t make a huge difference, but it’s always good to explore and see if others have insights or even tested this setup themselves.
Another consideration is the RF antennas. They’re designed to be omnidirectional, so the orientation of the device shouldn’t impact performance or range. This makes me feel more confident about trying out a vertical mount. If anyone has experience with this or has tested it, I’d love to hear about your findings!
For those looking to get started with vertical mounting, here are a few tips:
- Material Choice: Opt for durable materials that can withstand the weight and provide proper support.
- Heat Management: Ensure there’s adequate ventilation around the device to prevent overheating.
- Aesthetic Integration: Consider how the mount will look in your space and whether it complements your home’s decor.
I’m excited to try this out and see how it performs in the long run. If anyone has tried vertical mounting, please share your experiences and any lessons learned!
