Mounting Motion Sensors: Tips and Tricks
Hey everyone, I’ve been diving into setting up my smart home lately, and one thing that’s been on my mind is how to properly mount motion sensors. I came across the RE110P model and decided to give it a try. At first glance, the side mounting options seemed straightforward, but the rear mounting setup had me a bit puzzled. I noticed the two keyhole notches on the bottom, but they looked upside down to me. If I cut them out, would the sensor have to slide up to lock in place? That seemed a bit counterintuitive. I also wondered if I’d need to buy new screws specifically for rear mounting or if the flathead screws provided were sufficient.
I decided to give it a shot and ended up with a setup that works perfectly. The key was to carefully measure and mark the drilling spots to ensure the sensor aligned correctly. I also found that using a small level tool helped keep everything straight. If you’re looking to mount your sensors without any issues, I’d recommend taking your time with the measurements and maybe even sketching out the placement beforehand.
Another thing I learned is that while side mounting is great for quick setups, rear mounting offers more flexibility, especially if you want to place the sensor in a specific location without it being too visible. It’s all about finding the right balance between functionality and aesthetics.
If anyone has tips or tricks they’ve discovered while installing motion sensors, I’d love to hear them! Let’s keep the conversation going and help each other out in creating the smart home of our dreams. Happy tinkering! :rocket:
